Hi! I have a this new Multiplus installed.
I disabled the storage mode. When the unis is in float mode and it get hot in the compartment, bad ventilated small workshop, the internet temp goes up to 50 C. At that stage I get the internal temp warning, flashing red temp light, and the unit stops charging. When the unit cooles down everything is back to normal.
The cooling fan is never working. Is this a fault or a setting issue ? Should it run, even when in float mode there is no execs charging amp ?
Thank you for any tips/hints.
Regards Robert
