I have two Quattro 24/8000 units are setup in parallel , I am having a issue with Power Assist, in as much as the setting that I set the support at is not what happens in the real world
Ie I set the Power assita support level at Say 80 amps and the support then occurs at 57 amps
This diferance happens on AC 1 in and AC2 in settings
Quattro FW 459
CCGX FW 2.32~2
VRM access is available if needed on request
Everything seems to operate correctly though but the power ASSIST amps reading is out by a lot
AC1 is Mains
AC2 is generator
Now to get the Power assist to work on AC1 correctly on a 63 amp breaker I have had to set the amps at 80 on THE ccgx THEN the breaker amp reading is 57 amps
What should I do so that I can have the correct AC amp readings readings .
This site is on the VRM if you want to check anything
