dd33 avatar image
dd33 asked
Can "VE.BUS-SMART-DONGLE" be used only on devices - that have a "VE.BUS connection" ?
can the input current limitation of the "VE.BUS-SMART-DONGLE" only be used on devices - that have a "VE.BUS connection"?
I read the user manual for VE.SMART-DONGLE here:
https://www.victronenergy.com/upload/documents/VE.Bus_Smart_Dongle/106441-VE_Bus_Smart_Dongle-pdf-en.pdf
"VE.BUS-SMART-DONGLE" also offers these functions (Among others):
The inverter/charger can be switched to on, off or charger-only and the AC input current limit can be adjusted.
Can these "three" functions only be exploited by devices - which have a VE-BUS connection?
Here I give another example: These three functions (I assume) cannot be used with the “PHOENIX SMART IP 43 charger“ – because this charger does not have a “VE-BUS connection”? However, the PHOENIX IP43 charger could connect to “VE.BUS smart dongle” via “VE SMART NETWORK” – and then the charger could use the data received (From VE.SMART DONGLE) about „temperature“ and „voltage“ - to “optimize” charging the battery ?
Now I would like to ask - whether my "assumptions" - are correct or maybe wrong?
Thank you.
Dd33
VE.Bus Smart Dongle
Justin Cook avatar image
Justin Cook answered ·
The VE.Bus Smart Dongle can only control devices that have a VE.Bus connection.
If you would like VE.Smart Networking to use with VE.Smart Networking-compatible devices, the correct product to use would either be the Smart Battery Sense or a BMV-712 or SmartShunt.
ejrossouw avatar image
ejrossouw answered ·
It is for Multis, MultiPlusses, MultiPlus-II, MultiGrid, MultiGrid-II, Quattros and Phoenix Inverters with a VE.Bus port.
dd33 avatar image
dd33 answered ·
Hallo, thank you for the information.
