The following VRM Advanced Dashboard widgets/charts show no data.
PROBLEM 1: When the "Load Widget" button is clicked the following widgets are blank:
- VE.Bus State (no data)
- System - ESS battery life state (no data)
- VE.Bus Warnings and Alarms (no data)
- Battery Warnings And Alarms (no data)
The third and fourth would understandably only show data if there had been warnings and alarms for these, but there has been one battery warning recently (discussed in another thread), which never showed in this widget - it only showed in Remote Console Notifications until dismissed.
PROBLEM 2: Battery Consumed Amphours data is not showing in the following two widgets:
- Battery Consumed Amphours (no data)
- The Consumed Amphours field in the Battery Summary widget (the other fields do show)
All other widgets show data.
- Alarms & Warnings for all categories, and "VE.Bus error" are enabled in Remote Console.
- Monitor for Grid Failure is enabled.
- Settings -> System Setup -> Battery Measurements displays "Visible" for the Multi and battery.
Browser is Edge on Windows 11. Same issue on iPhone.
Hardware: EasySolar-II GX 48/5000/70-50 (all components latest firmware) and Dyness Powerbox F-10.0 9.6kWh.
Any ideas folks? I've reviewed all similar issues posted but none are like this.
Thanks
