As stated above.
Is there an equivalent of SUB (solar, utility, battery) priority mode in the Multiplus II as you have in some other inverters ( eg Growatt)
What this means is that Solar powers connected loads as first priority, when solar energy is not enough, Utility is added to the Solar to compensate the difference. When neither solar or utility is available then the battery is used.
