tronegeden avatar image
tronegeden asked
Inverter low battery threshold reasonable limit
capture.pngHello,
Looking at my Easysolar 48/5000 configuration I am wondering what could be a reasonable (and safe) DC input security setting in the Inverter tab.
Assuming the inverting draw too much for any reason there is a limit. Put very simply 48 volts would mean 12,0 per battery module ... wich is low...too much low.
Considering 12,6 the bank should measure at least 50 volts.
I know my take is not very realistic but I am curious how guys do you handle this ?
Regards
Philippe
MultiPlus Quattro Inverter Chargerlow battery warning
nickdb avatar image
nickdb answered ·
You use the battery specification to guide you.
This is a backstop, it should never be needed and your goal is to protect the battery and allow the system to self-recover.
Supported lithium batteries define all these parameters.
So it is a question best posed to the battery manufacturer.
