Dear Community,
- i have a 3-Phase Quattro 15K with ESS-Setup. (Firmware 497)
- Living in germany required me to setup a external NS-Protection by using Ziehl UFR1001E to comply with VDE-AR-N 4105:2011-08 or VDE-AR-N 4105: 2018-11
- As it is required by my local Network, i need to comply to some settings like for COSϕ, as it is described in DIN VDE V 0124-100 (VDE V 0124-100):2020-06.
- I know the QUATTRO 15K is certified to comply with ...
 --> VDE-AR-N 4105: 2018-11...
...based on Test defined in ...
 --> DIN VDE V 0124-100 (VDE V 0124-100): 2020-06. “Network integration of power generation systems – Low voltage"...
... by ...
--> Certificate-ESS-VDE-AR-N-4105-2018-11-Quattro-48-8000-110,-48-10000-140,-48-15000-200.pdf
Here comes the Problem:
- VE Configure 3 just offers me Grid-Code VDE-AR-N 4105:2011-08 and within this Grid-Code i also can´t make any changes, e.g. to COSϕ
How can i either change settings on values like COSϕ (as it is for example possible in other Grid Code... (Here TOR Erzeuger Austria..)
...or how can i get to select Grid-Code...
 --> VDE-AR-N 4105: 2018-11 (with external NS-Protection) ... like i have seen it in Screenshots in in a different Post....
Screenshot with QUATTRO having VDE-AR-N 4105: 2018-11
.. where i assume i will automatically comply to the right settings defined by my local network provicer (like COSϕ .. settings)
