I'm installing an Orion DC-DC Charger Isolated. I also am installing a BMV-712 Smart Shunt. Is it correct that the ground (negative) cable from the supply battery should be connected to the output side of the shunt, as opposed to connecting it directly to the negative terminal of the supply battery straight to the charger?
