I think i have everything set up per specs, but am having some nomclemature uncertainty-I think my batteries were undercharging with the default setting i was using
I have an AGM 350AH battery bank being charged by a 320w panel. My batteries have a float charge rec of 13.5-13.8 and a recharge voltage of 14.4-14.8. I set these to 13.7 and 14.6 respectively on my MPPT. I have auto equalization turned off.
On the BV712, it recommends setting the "charged" voltage to slightly under the absorption voltage when using solar. Would i use the recharge voltage number as my reference, and then set my charged voltage slightly under this, to around 14.2 volts?
Thanks in advance for any help!
Best
Ian
