Hi
I'm trying to setup Grafana on Raspberry Pi 4 but keep having different issues. Based on the GitHub link, when composing the file I get the following output;
Basically the issue is the compose is seeing it as non-windows PC I believe?
- ! server The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm/v7) and no specific platform was requested 0.0s
- ! graphing The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm/v7) and no specific platform was requested 0.0s
Can anyone help. Thanks.
- pi@raspberrypi:~/victron $ docker compose up -d
- [+] Running 43/26
- ✔ graphing 11 layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulled 95.5s
- ✔ server 11 layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulled 336.7s
- ✔ upnp 9 layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulled 334.8s
- ✔ influxdb 8 layers [⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulled 172.8s
- [+] Running 6/8
- ✔ Network victron_default Created0.8s 0.1s
- ✔ Volume "victron_grafana-storage" Created0.1s 0.0s
- ✔ Volume "victron_config-storage" Created0.0s 4.8s
- ✔ Volume "victron_influxdb-storage" Created0.0s 4.8s
- [+] Running 6/9ctron-influxdb-1 ✔ Network victron_default Created0.8s ✔ Volume "victron_grafana-storage" Created0.1s ✔ Volume "victron_config-storage" Created0.0s ✔ Volume "victron_influxdb-storage" Created0.0s amd64) does not match the detected host platform (linux/arm/v7) and[+] Running 6/9ctron-influxdb-1 ✔ Network victron_default Created0.8s ✔ Volume "victron_grafana-storage" Created0.1s ✔ Volume "victron_config-storage" Created0.0s ✔ Volume "victron_influxdb-storage" Created0.0s d64) does not match the detected host platform (linux/arm/v7) and ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.1s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.2s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.3s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.4s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.5s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.6s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.7s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.8s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting5.9s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.0s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.1s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.2s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.3s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.4s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.5s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.6s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.7s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.8s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting6.9s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting7.0s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting7.1s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting7.2s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting7.3s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting7.4s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting7.5s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting7.6s
- ⠿ Container victron-influxdb-1 [+] Running 6/10 Starting7.7s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting7.8s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting7.9s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.0s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.1s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.2s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.3s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.4s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.5s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.6s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.7s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.8s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting8.9s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting9.0s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting9.1s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting9.2s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting9.3s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting9.4s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting9.5s
- ⠿ Container victron-influxdb-1 [+] Running 7/10 Starting9.6s
- ⠿ Container victron-influxdb-1 [+] Running 8/10 Starting9.7s
- ⠿ Container victron-influxdb-1 [+] Running 9/10 Starting9.8s
- ✔ Container victron-influxdb-1 [+] Running 9/10 Started9.8s
- ✔ Container victron-influxdb-1 [+] Running 10/10 Started9.8s
- ✔ Network victron_default Created0.8s s
- ✔ Container victron-influxdb-1 Started9.8s
- ✔ Container victron-server-1 Started10.0s
- ✔ Container victron-upnp-1 Started7.9s
- ✔ Container victron-graphing-1 Started9.7s
