Newmar installed RJ45 Ethernet cable as part of solar prep on Dutch Star motorhome. However, they swithced over to Victron Inverter (lower bay) and Victron Cerbo GX and monitor (overhead driver panel). I installed Victron MPPT 150/35 not knowing it would not have RJ45 connectors. The RJ45 cable can't be pulled through loom to bring 2 VE Direct cables. Guy who installed my solar panels thinks he can successfully sut/spllice/sodder to use the 8 wires in the ethernet cable for both 4 wire ve direct cables (MPPT and Shunt com) Newmar's solar contractors do not think this will work. Other opinions ?
