Hi! Can anyone help me to configurate correctly my solar system?
I have Multiplus 48/1600/20, MPPT 100/20, LiFePo4 battery without bms and two solar panels 450W each. ESS with Optimized mode (With BatteryLife) and without feed-in. But sometimes on VRM I see that small amount of energy goes into the grid. The main idea is to make system work like this:
When solar power isn't enough to cover the load - battery will discharge till specified voltage or SOC.
When solar power is enough - extra power will charge the battery.
System can take the energy from grid only when battery rich the minimal SOC or there is no solar power.
I need to survive without the export from grid as much as possible.
Is it possible to configure system like this and should anyone help me with this?
