davecason avatar image
davecason asked
Newbie question about a Smart Shunt
Hi, The older smart shunt in my system and it works fine. I can view it on my phone whenever I like.
However, I'd like to see it on my PC as well - the PC does have Bluetooth and it has been turned on and then paired with the shunt.
I then downloaded Victron Connect and ran it, it runs but it says it can't see anything then on the next page after I click: "Don't see the product you were looking for?"
The first line says: No Bluetooth on Windows
Bluetooth connection from a Windows device is not supported. Use appropriate .......
So I guess there is no way to use Bluetooth on my PC to view the data in the shunt? I can't find a copy of the manual for the shunt, at least not yet so I can't RTFM yet.
Is there a way to get the Victron Connect program on my PC to see the shunt?
Cheers'
Dave
SmartShuntVictronConnect
klim8skeptic avatar image
klim8skeptic answered ·
@davecason Is there a way to get the Victron Connect program on my PC to see the shunt?
Sure you can connect your Smart Shunt to a computer. You wil need a Ve Direct to usb cable as linked in the Smart Shunt manual.
Kevin Windrem avatar image
Kevin Windrem answered ·
You should NOT pair the shunt in the bluetooth control panel. Go there and forget the device and try again in VictronConnect.
davecason answered ·
HI,
Yep I got a copy of the manual and I ordered a: VICTRON ENERGY ASS030530010 VE.Direct to USB interface - it will arrive in a few days. I'll get it plugged up and in to the PC and try the software then !!
I did also remove the Shunt in the Bluetooth settings but the Victron Connect software still can't see it, it's happy enough on my phone but no joy on the PC, I need that cable !
Thanks for the help !
Cheers'
Dave
marcve avatar image
marcve answered ·
It is possible your PC is to far away from the smartshunt. Range of the smartshunt is rather "weak".
