Hi Folks,
I'm looking to add EV Charger (ns version) to my system. Currently have multiplus ii with ESS wired on ACIN (grid parallel). I would be installing the EV charger also on ACIN side (parallel to grid).
My first question is does the EV charger have a setting to limit draw from the grid? ie say batteries are 0, EV charger is on but I also have large loads running in the house?
I know other EV chargers have a CT clamp on incoming supply to prevent overdrawing from Grid and blowing house fuse? I can see in the manuals it has a max draw setting but does it have another setting that monitors via venus os/ET112 what it's from the grid ie so fuse wont blow.
Does EV charger have feature for this given meters/ct clamps are already on incoming grid supply for ESS setup?
Also is there a feature just for EV Charging to be from the grid? ie My normal house loads i want running on the battery but if EV charging below SoC of say x % i want it to draw from the grid.
Or do i need to get creative with Grid setpoint and node red to implement something like that?
ie grid set point = ev charger load
