I've replaced a normal venus os 2.8x with large venus os 2.93 on a raspberry pi 3. I moved over the /data partition, and from what I can see all settings were preserved: wifi, uploads data to vrm as expected etc.
Node red starts, and standards nodes works fine. However, victron nodes does not seem to work. Here's a screenshot of a System node. Notice the "System" and "Measurement" dropdown lists are empty. The same problem exists on other victron nodes too.
Victron Smartsolar MPPT and BMV-700 is connected using Victron USB VE.direct adapters, and a Multiplus is connected using Victron USB VE.Bus adapters.
Any tips?
