trevor-w avatar image
trevor-w asked
Battery Protect - have I fried it?
Hi, Just fitted a Battery Protect Unit to my motorhome. Failed to read the bit about not adding the load to it until I'd programmed it. I now can't get anything up on the screen when I ground the Prog connection as per the manual. Battery showing 12.9v off charge, 13.2 on charge. Is it recoverable?
Battery Protect
trevor-w answered ·
Sorted .. I'd also not picked up on having to turn the device off by removing the looped plug. I'm usually better than this at fudging my way through stuff .. ah well.
