crunch42 avatar image
crunch42 asked
Huge difference between battery voltage reading for MPPT in VictronConnect and multimeter
VictronConnect shows battery voltage around 12.1, but a multimeter on the battery terminals themselves and on the MPPT 100/20 charge controller's battery terminals both show 12.8. Defective unit?
MPPT ControllersVictronConnect
crunch42 answered ·
Thanks, it turned out to be a bad multimeter.
Paul B avatar image
Paul B answered ·
Two posibilites here
1. the testing volt meter is not correct, as a lot these cheaper meters can give incorrect readings
2. then the MPPT unit is faulty, take it back for testing/ replacement. ( I see very few to nill mppt units with this sort of issue)
3. MAYBE have you anything else conected ie tempature compensation for battery charging, is the regulator in a hot place, are the batteries and the regulator at the same tempature. etc ceck all the settings using the victron connect app
