expedition avatar image
expedition asked
48V Balmar Alternator to charge Lithium Bank
Hi Guys, I hope you can help me on this one:
I have a system using a Multi RS Solar 48/6000/100. Have AC Input-Solar Input and need to charge the 5 US3000C Pylontech batteries using a 48V Balmar Alternator.
Can I plug the Balmar Regulator directly to the Batteries or should I need some device in between?
Thanks!!
Pylontechalternatorbalmar
jessiejim1 avatar image
jessiejim1 answered ·
I don't recommend connecting an alternator directly to the batteries as the alternator can produce a high charging voltage that may damage the batteries. Therefore, it is important to have a charge controller or a battery isolator in between the alternator and the batteries.
djsmiley avatar image
djsmiley answered ·
Balmar has (just as eg Wakespeed) alternator regulators which support lithium
https://balmar.net/wp-content/uploads/2020/03/PDS-MC-620-H.pdf
iand avatar image iand commented ·
The Wakespeed WS-500 is more capable than the Balmar and is also now supported by Victron (don't know if the Balmar is).
expedition answered ·
Yes, Im saying connecting the Regulator (Balmar MC 620) Directly to the batteries
djsmiley avatar image djsmiley commented ·
You do need a 12V powersupply (DC converter like Orion-TR 48/12) since the MC-620 needs 12V.
expedition avatar image expedition djsmiley commented ·
Yes, I will input 12V to the mc-620. But after that. I can plug the regulator directly to batteries or do I need a battery isolator or any other hardware?
djsmiley avatar image djsmiley expedition commented ·
Yes. Only add a fuse close to the batteries and configure the MC620 properly.
dj-dulux avatar image
dj-dulux answered ·
Only issue I see is if the Pylontech protection turns on the alternator will generate a huge voltage spike and likely damage alt and controller. I am working with the same dilema at the moment... Looking at a NodeRED solution reading DVCC CCL, if above 140A then enable charging relay, if not don't allow charge to prevent protection kicking in.
Cheers,
Dupe...
Victron Pylontech battery compatibility guide
