tsypowicz avatar image
tsypowicz asked
MPPT Questions
I have 6 x 445w Canadian solar solar panels I'm not sure what MPPT i'm suppose to get. I'm looking at 3 x VICTRON SMARTSOLAR MPPT 150/45. 2 solar panels per MPPT I don't want to leave any meat on the bone should I buy a bigger MPPT? or does the 150/45 for 2 panels do the job?
MPPT ControllersMPPT SmartSolar
ahtrimble avatar image
ahtrimble answered ·
tsypowicz avatar image tsypowicz commented ·
I tried its blank thats how I ended up here. So far victron has been little to no help
nickdb avatar image nickdb ♦♦ tsypowicz commented ·
Try a different browser. The calculator is working perfectly and is the right tool for the job.
ahtrimble avatar image ahtrimble tsypowicz commented ·
I tried it just now...it comes up and works fine. Check your browser for compatibility.
z-zk-z avatar image
z-zk-z answered ·
What is your 445-watt open circuit voltage value? Isn't it close to 50 volts? NOTE: the open circuit voltage increases as temperature drops. You don't have to worry about it, if you live in a warmer area. Anyway, I am using 450-watt solar panels with 49 open circuit voltage and I live in a warm area. I was using Victron MPPT 100/20, with two solar panels in series and never saw voltage going above 90 volts. I am now using a Victron MPPT 150/45. If you want to be safe (and live in a cold area) and got tons of money, go ahead and purchase 3 Victron 150/45 and connect two solar panels in series to each. However, if you want to save money and live in a warmer area, just purchase two Victron 150/45 and connect three solar panels in series to each. However, if you really want to save money and check out how your solar panels are behaving, I would recommend to purchase just one Victron 150/45 and connect two strings of solar panels in parallel (with three panels in series in each string, aka 3S2P) to the MPPT.
So your 445w PV is about 9.2a (+/-) @ 48.5v Yes?
I personally would look at running 3 strings of 2 PVs each on a SmartSolar MPPT 150/70 VE.Can.
That gives you 97v & 9.2a on each string. The 3 strings paralleled together gives you 97v @ 27.6a.
That is plenty of headroom on the volts, and plenty of room to add additional strings of PVs when/if you want to. And that means a single MPPT...and that mondel is a very good one!
And yes, I run that MPPT and a non-Can version of that MPPT. I run 6x250w PVs (3S2P) on one array/MPPT and the other MPPT runs 2 separate arrays #1 - 6x250w PVs (3S2P), #2 - 8x100wPVs (4S2P). Each MPPT has a separate sun orientation.
MPPT Product Page
MPPT Error codes
