I have a 4x265W panel array connected in parallel due to partial shade early morning and late afternoon. I suspect my MC4 connectors are a source of losses in my system as I only produce max 500W in full sunshine when peak production should be (albeit in theory) double that value . When connecting in parallel ut becomes very difficult to disconnect the MC4 in the middle of the array of 5 connectors. Does anyone have an alternative connection solution than MC4? I thought about using earthing bars and putting all wires in an IP65 box but the earthing bars I find don't extend to 10 and 16mm2. Thanks.
