maximiliaan avatar image
maximiliaan asked
Multi RS setup
I am trying to set up a new system, with 18x 370w panels JA solar), 1x Multi RS Solar inverter/charger and 3 Pylontech batteries (US5000) and a Cerbo. Thought about 2x 9 panels in serie. Its going to be installed in Kerry/Ireland, and has to be ground mounted. Thank you in advance.
smart solar set-up help
Jons Collasius avatar image
Jons Collasius answered ·
What was the question? I'm missing the question mark.
You should use the MPPT Calculator to check if your string setup is valid for your MPPT.
https://www.victronenergy.com/mppt-calculator
