denzel avatar image
denzel asked
Are you adding fans to your MPPT Controllers ?
Hi All,
If you have a Victron MPPT Charge Controller you most probably noticed it can get very hot to the touch. I have seen some guys add fans to the unit like below.
I have checked my 250/100 MPPT controllers with Thermal imager and I have recorded +- 56 degrees at times.
Victron says there units can run "Operating temperature -30 to +60 °C (full rated output up to 40 °C)" .
Are you cooling your units down and how?
MPPT Controllers
nickdb avatar image
nickdb answered ·
Nope, and this is a warm weather region.
They cope just fine.
n-dee avatar image
n-dee answered ·
I'm cooling one of them (250/100) as it gets 65 degrees and limits to 5400w
Where did you get your parts? That looks interesting!
Michelle Konzack avatar image Michelle Konzack commented ·
I am also interested in this parts
johnone avatar image
johnone answered ·
Mounted on aluminum angle to help with air flow.
nigely avatar image
nigely answered ·
Found mine getting very hot inside a cabinet so cut a hole behind it and mounted a 12volt 4” fan directly behind it in the next cabinet can now put my hand on it.
denzel avatar image denzel commented ·
Is your fan extracting?
Michelle Konzack answered ·
@Denzel
Where did you buy the cooling set please?
Hi Michelle,
I didnt , i found that on the internet. You could similar on https://www.thingiverse.com/and 3d print it.
