I have 2 charge controllers, one is 100/50 and the other is 150/60. Can I run and combine 6awg wire from both to a 100a breaker and then run a 1/0 wire from the breaker to the lynx distributor with a 125a fuse? OR do they have to remain separate? Also does a sterling b2b charger have to attach to the lynx distributor or does it really only have to connect to the house battery on the back end.
