alaskannoob avatar image
alaskannoob asked
MPPT RS designed to purposefully limit DC battery cable size? Why?
mppt-rs.jpgJust measured the slot that allows DC cables into the MPPT RS 450/200 terminals, and it will only allow .6" diameter cables. I have 2/0 cable that has a finished outer diameter of exactly .6" but the heat shrink is a bit more than that. I'd like to connect 4 x 2/0 cables (two positives, two negatives) to lessen my voltage drop and for the interest of safety.
I'm considering shaving a portion of the slot as needed to fit the 2/0 cables in. But it seems the MPPT RS slot is designed to limit the DC battery cable size purposefully. Is there a reason why bigger cables are not desired on this MPPT?
mppt rs
Alexandra avatar image
Alexandra answered ·
@AlaskanNoob
Weird.
We have installed a few. They take the 70mm² cable quite fine. We used 2x 70mm² cable for the longer runs.
Maybe the manufacturer of the cable you have purchased has slightly thicker than normal insulation?
alaskannoob avatar image alaskannoob commented ·
That's quite possible. This is the wire I'm planning to use (four of them):
https://store.polarwire.com/arctic-ultraflex-2-0-blk/
Michelle Konzack avatar image
Michelle Konzack answered ·
Also the heat shrinking tube can be a problem if chosen to big.
In my first attempt it made together with the glow inside my 70mm² around 4,5mm thicker which was not a good thing.
