ukxan avatar image
ukxan asked
3S2P query
Good evening,
my setup:
ES 2GX
RS 450/100
2X PYLONTECH US5000
CANADIAN SOLAR 410WX6
I have CANADIAN SOLAR 410WX6,can I connect 2 strings in parallel with each string having 3 panels in series for the inbuilt ES2 GX MPPT 250/70 (as it has onlt 1 tracker)? Can the positive of each string be joined together to go to the + of the MPPT controller and likewise for the 2 negative terminals of the 2 strings to go to -ve of the MPPT controller?The RS 450/100 has its own 2 strings.
Many thanks
MPPT Controllers
Jons Collasius avatar image
Jons Collasius answered ·
That goes without a hitch. I have practically the same set-up with three modules per string and two strings in parallel.
Both positive poles of the strings go to PV+ and both negative poles go to PV -. Double check the correct polarity.
However, the modules of the strings should be aligned in the same way, i.e. not east/west.
