i want to enable two way communication with vrm portal but since i'm not using cerbo or venus os its not easy as to enable an option.
i wonder which package or setting enables the two way communication?
is it vrmlogger ? i see some debug msgs from it /data/ vnc tunnel failing.when running. is it how vrmlogger connects for two way communication ? anyone knows the settings or packages to install on debian to enable it ? looks like if i give it vnctunnel it will connect but i couldnt see any documentation or mentions about it
