Boat installation 1.5hr drive to check new 300a/h 12v DIY LIFEPO4 install. Maybe time for VRM. 123Smart BMS signals 100/50 smart mttp via victron non-inverting remote on/off cable plugged into the charger. All good. This provides signal to the charger for on/off. Space is limited & adding Cerbo etc could be a problem. So if the RX port is held up (turned on) would there be information coming from the TX port at the same time to provide information to use the VRM? i.e. Does victron VE direct port provide 2-way comms?
Regards Bill (Ancient Mariner & retired electronics tech)
