So a few days ago I switched from my old 14s 18650 li-ion battery (only 18 ah in capacity test) To a 16S 125AH LiFePo4 battery (Build from CALB Prismatic cells). I'm not sure if my charging settings are corret and also the smart shunt settings.
Battery specs:
16S 3.2V - 51.2V
125AH
Charge/Discharge max: 1C
BMS: JK-BD6A20S10P
BMS Cell Over-Voltage Protection: 3.6V (57.6V)
BMS Cell Unver-Voltage Protection: 2.7V (43.2V)
System specs:
Victron MultiPlus-II 48/3000/35-32
Victron SmartShunt 500A
Victron BlueSolar Charger MPPT 150/45 rev3 (6x 285W, 6x 225W panels)
Aliexpress Grid-Tie PVGS 180W (1x 100W panel)
Aliexpress Grid-Tie PVGS 350W (1x 285W panel)
ACS712 30A + Arduino Nano for dedicated DC-System meter
3x DS18B20 Temperature sensors + Arduino Nano for 3x Temperature sensors
Raspberry PI 3 B+ with venus os acting as venus device for victron vrm monitoring
Also some ess questions:
1- What should my grid setpoint be to have the lowest grid consumption without exporting to grid form battery? (Grid export is allowed but dont get paid anything so would like to keep it at 0W)
2- In ess system do the mppts use their charge settings or are they ignored and synced with the multiplus charge settings?
Here are my settings, Tell me if i should change anything or if its good:
Multiplus - Inverter:
Multiplus - Charger:
Multiplus - ESS:
Smart Shunt:
Mppt:
