javi avatar image
javi asked
lev50n yuasa with ESS fronius primo 6k + quatro8k
red light low battery always on.
battery pack 13s3p of yuasa lev50n (max volt 4.1 and min volt 2,75 - 50 A)
REC Q BMS
min volt pack 2.75x13 =35,75 V
max volt pack 4.1x13=53.3 V
when not enough photovoltaic never works battery only the external grid as backup
ESS installed and all firmware ok
some help in ESS configuration
ESSBMSFroniusVEConfigure 3low battery warning
Paul B avatar image
Paul B answered ·
check you Ess Assistant as this may have the incorrect low voltage level
