Dear All
I have been looking on this platform if old posts can assist me but I find myself still having a few questions.
I have a MP2 (5kva) and a CerboGX with all the other necessary items for 48V to 220V configuration (Grid-tie).
My kitchen is some distance from the MP2/GX and most of the "heavy lifting" happens in the kitchen. So for this reason, a touch 50 / 70 will not be able to reach the preference place (view point) so that all can see when they switch on loads.
Our local grid is terrible (to say the least) and we have daily outages that can last 2 to 4 hours.
My question : is it possible to install a LED to one of the relays in the MP2 (green connectors) or use the GX relays (built in) to turn on the LED when the grid is out (either by NC or NO relay configuration).
If so, should I connect a 5V (or 12 or etc.) load to the green connectors (that passes through the relay) or can this be configured to power itself.
If anyone can point me to the literature that gives a detailed explanation to what each slot do within the GREEN connector (or GX) with the its current/voltage limitation, I will be able to figure it out on my own.
However, If any of you have done this previously, I would highly appreciate it if you can send a photo or diagram my way.
Thanks in advance
