arrow1800 avatar image
arrow1800 asked
Websockets in node-red not working
Hi all,
Ik have a cerbo gx with node-red running on it. i am trying to create a websocket listener but i am not able to connect it. I also have another node-red installation running(no victron/cerbo, just a normal raspberry) where the following IS working.
node-red is running at: https://192.168.2.70:1881/
and the websocket is listening at: /ws/test
The url should then be: ws://192.168.2.70:1881/ws/test
Is there some kind of proxy blocking websockets on the cerbo gx perhaps?
Node-RED
Dirk-Jan Faber (Victron Energy) avatar image
Dirk-Jan Faber (Victron Energy) answered ·
I don't believe there is anything blocking it. And I think you want to use wss instead of ws. But I haven't done much with websockets so I might be wrong.
You might also want to check out the answer here, if it is the https part that is giving the problems.
Marius Marais avatar image
Marius Marais answered ·
It seems websocket connections are only supported on the /comm path by the nginix configuration.
So you need to configure your websocket listeners for /comm/xxx and then connect to wss://192.168.2.70:1881/comm/test
-gerhard avatar image
-gerhard answered ·
Could you bring it to work? I'm fighting with the same problem :(
