I have a 25A Bluesmart 12v IP65 charger which I am permanently installing in my Ute canopy connected to a 170ah lithium battery. On the DC(output) side of the charger the cables are too long and I'd like to cut them shorter, add lugs and wire through a MIDI fuse on the positive lead. Will the charger still work properly with the DC side cables cut shorter and wired through a fuse?
Cheers,
Tom.
