I have just bougth a raspberry pi 3b v1.2.
Downloaded the latest wic.gz according to the insstructions.
pugged it in but it stops at a promt screen according to my fig below.
its plugged in to my local networkk but venus.local does not work.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
It's up and running...in web browser on your pc type ip adress of your raspberry pi and will open remote console...
Tested to type victron.local according to a guide does not work
Can I see what/if the rasp has got an ip somhow?
You must login on your router.There is setting with list of all conected devices to.
I found the error...there were no more ip adrresses avaliable so now Im connected. Run into another issue ... I had another install on another raspberry pi connected to VRM-portal (were everythong worked).
I now removed that old ID and added the new one. My solar charger has popped up but not my multiplus that was "turned off" in the old VRM id.. I have tried to turn on and off the mutliplus on the manual swith but it does not seem to "wake up" ...
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
52 People are following this question.
