Devices:
1x Victron Quattro 15000VA
2x Smartsolar 450V 100A
4x Weco 5K3 Battery
1x Cerbo
I want to eliminate all residual grid consumption, just treat grid as a generator and use it only below minimum SOC.
I cannot set the grid setpoint below 50W cause I cannot inject energy in the grid.
I know maybe ESS assistant is not intended for this, but I cannot see other assistant with the features and easy of control of this one.
As far I know, generator assistants, etc, aren't based in battery SOC but voltage, and that's clearly worse and neither can change parameters from VRM, etc.
Maybe the topic is repeated here: https://community.victronenergy.com/questions/81769/grid-independent-ess.html but cannot find a proper answer there.
Please, any advice to config this or future update to add the feature?
Thanks.
