12v system.
under ac out load of 1500w+ one or both mppt 100/50s stop producing.
I wonder what could be causing the loss of power from the mppts during high loads?
update:
Changed a couple of things around, removed the MPPTs from the network (had them networked via bluetooth prior to adding cerbo) rebooted everything. still same issue. Did not have this issue prior to adding the cerbo and lynx distributors/shunt.
Also, see the red lights on the lynx on the right. There are no blown fuses in there and the lights go back to green when the MPPTs start sending power again.
update:
all connections secure, still the issue persists.
