I'm having some strange readings on the MPPT's and PV production.
The system is Cerbo GX controlled with 2/ 10KVA inverters, 3/ 450-100 MPPTS and 8/ Pylontech 5000 batteries. PV is 5 strings of 12 panels each (60 panels) facing 45deg due South with no shading.
The MPPTs are connected to VE.Can, Batteries to VE.Bat and inverters to VE.Bus with all spare VE.Can/Bat sockets terminated.
The issue I'm having is with the PV generation fluctuating as per the video attached. 2023-02-08 09.25.47.mp4
Comparing this to another system I have running, is it severely under generating and it's strange differences between strings when they are all the same. Is there a way of seeing the commands being sent around the system so I can try and work out whether its a PV / control or component level issue?
