I have a BMV-700 and a smart solar MPPT connected to a RPi or to a VE.Direct Bluetooth Smart dongle.
I use to switch between VRM portal and local BT connections depending on if I am in my RV or on distance. Can I instead of dragging out and switch the cables from the BMV and MPPT, cut the VE-direct cable and the VE.Direct Bluetooth Smart cable and merge them?
Sharing one connector into BMV, split the cable into two where one go to the BT part and one goes to the RPi via USB?
Sharing one connector into MPPT, split the cable into two where one go to the BT part and one goes to the RPi via USB?
Stupid? If so, please apologize!
