Does anyone know of a way to send a tank reading (will be a 0-5v tank sensor resistance type) wirelessly to a cerbo GX? I assume wireless devices exist just cant seem to find one that isn't a self contained unit?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Many thanks Kurtinge, which sensor did you use and how does it connect to the cerbo?
Only the Mopeka Pro Check (LPG and water) is supported. No other Bluetooth tank sensors.
Here's some pictures installed. I put set a hatch cover into the underbelly of the RV to access the sensors when it comes time to change battery. Mopeka take note, I bet with the little current they draw if you put a mechanical charger in there, the vibration from driving an RV down the road could probably keep the battery charged.
37 People are following this question.
