aplord avatar image
aplord asked
VRM y-axis auto range incorrect
See attached the standard widget showing voltage and current for a shunt. Since it's not a custom widget, the Y axis is set automatically by VRM. The range it has decided on is 22-30 volts, with no data showing. The battery voltage in reality, as reported by the same shunt (device 279), is actually around 13.5 volts - as shown in the custom voltage widget where I set the range myself.
This auto widget used to work correctly, I'm not sure exactly when it stopped working. I can't think what I might have done to upset this! Any ideas? Thanks in advance.
widget vrm
Hi aplord, noted, the developers will look into it. Thank tou for asking. Matthijs
aplord avatar image
aplord answered ·
Here's another piece of hopefully helpful info for your developers: when I point at the range on the widget, the correct voltage data values are displayed - see attached. So the right data seems to be getting to the widget, it's just getting confused about the axis range.
