I'm pulling data from Cerbo via Modbus periodically. Timezone is set correctly but the solarchargers ( I have 3 ) Yield Today fields (modbus address 784) is reset to zero during the evening few hours before the midnight, my timezone is set correctly (Czech Republic GMT+1.) Technically there's not issue as there's no sun in the evening, but my external dashboard is showing then 0kWh. I'm not sure if this is normal behaviour, but I'd just expect the data to be reset during midnight so it's technically correct as it's called Yield Today. Do you please have any clarification about that? Thank you.
