I would like to use an opto-isolator to turn off and on MPPT charging (this is fed by a charge enable signal from my BMS). The opto-isolator I'm using is an 817. The maximum collector current on the 817 is 50 mA.
The MPPT Manual states:
"3.5 Remote on-off
The left terminal is connected to the internal 3,3V supply, with a resistor in series for short circuit protection. The right terminal (marked as + or marked as H) will switch the controller on if >3V is applied, and will switch the controller off if <2V is applied or if the terminal is left free floating. The recommended use of the remote on-off is:
a. A switch wired between the left and right terminal
b. A switch wired between battery plus and the right terminal.
c) A switch between the right terminal and the charge disconnect terminal of a VE.Bus BMS"
I would like to know what the approximate value of the resistor is to ensure that when my opto-isolater is on, the collector current doesn't exceed 50mA. Can anyone comment on this value?
