We have a Victron Quottro 5kw and when connected to shore power it runs our Bauer Varius dive Compressor.
However when not on shore power it starts to turn the motor slowly but then goes into an overload error.
The motor is a 2hp 13A 230v motor however it does say 60hz but its always been OK on 50hz at home and as I say when on shore power.
The Cerbo GX says its drawing just over a 1000w when running ad you can see from the enclosed picture.
I thought it might be an aging capacitor fault so I fitted a new 700uf capacitor but it's still the same.
If I run the motor with the belt disconnected, so zero load it runs on both shore power and with no shore power from our 600ah Lifepo4 battery bank
