joergsc avatar image
joergsc asked
Node-Red maximum system grid feed in value
I want to send the "maximum system grid feed in" Value via Node-Red to the "Venus settings"
This works fine so far, but If I send a value >32767, I get "Error: Number outside range".
On the GUI I can set a higher Number, so I assume it's a setting on the Victron Nodes.
On the GUI I have also the Option "Limit System Feed In" (Systemeinspeisung begrenzen), there is no Node for this yet (at least I can't find it), is it automatically handled?
So maximum feed in value is "-1" the "Limit System Feed In" is unchecked and if value >0 the option is activated?
Node-RED
Harold Halewijn avatar image
Harold Halewijn answered ·
Hi @JoergSC , have you found a solution for this? I'm also searching for the nodered flow to control the Limit System Feed-in but I can't find it.
txs.
Harold
matt1309 avatar image
matt1309 answered ·
Hi @JoergSC @Harold Halewijn
Do you just want to enable/disable the "Limit system feed in" if so you just pass -1 to the Maximum system grid feed found in ESS control node to disable it, or am i miss understanding what you need?
Harold Halewijn avatar image Harold Halewijn commented ·
That's what I want to do, but it is not working.
matt1309 avatar image matt1309 Harold Halewijn commented ·
Hi @Harold Halewijn
It works for me. What version of venus os you running. Here's the test i did to make sure it was working.
Inject node as such:
And just to confirm this disables this setting: Normally i have set to 3400w but ran the above inject as a test and it's turned it off.
Weird, first I wasn't able to control it but now it works. Thanks anyway, you helped me in the right direction.
