Hi all, I have installed a 12/12-18 isolated Orion dc charger in my Ford Ranger. It’s charging a 100ah lifepo4 battery.
I have the “smart charge” feature turned off in my Ranger (done by the dealer) so the alternator always puts out around 14 volts.
The cable down to the tub is rated for 50amps.
The Bluetooth app on my battery says the charger is delivering about 8amps. I was expecting around 15.
The input voltage at my Orion is about 13.5.
Are my expectations way off or do I need much bigger cables to get better charging output?
