I am installing my "Electric Yacht, Quiet torque" motor and am wanting to sanity check a design choice I made. The plan is to have a Quattro 48/10K charge a few strings of batteries and those in turn run the motor. I believe if the battery bank for some reason is offline, I can run from the 110v AC generator to the quattro, the Quattro to the motor, and direct drive from the Quattro all day. I understand I would be down on power as the quattro can only put out 140 amps. My question is am I right ? Can the Quattro output a full 140 amps (or less if maneuvering at lower speeds) for say 24 hours straight with no batteries in line ?
