I'm running a setup in an RV with Home Assistant. I'd like to auto switch the "AC input 1 source type" depending if my generator is turned on or not to maximize battery charge behavior (yes, it does differ, battery charges to 100% with ESS when set to generator, maintains set percentage if shore or grid).
I don't mind forking the Venus OS if needed and submitting a PR if I can get some tips on where to start.
Edit: Looks like this is the line: https://github.com/victronenergy/dbus_modbustcp/blob/d65f8fc04444e9779e059fe867b3aad9f6e8ebe4/attributes.csv#L240
