I run a MultiPlus-II 48/5000/70-50-GX with a SmartSolar MPPT 100/ 20 -48V. There is a VE.direct cable between them so the GX module also shows info / can control the MPPT.
I would like to add a shunt to the mix, but the Multiplus GX only has one VE-direct port, and all the shunts seem to use this. Is there a shunt that can use one of the other connection ports or do I have to go over to an external GX, like the Cerbo GX? Will the Multiplus GX deal with being connected to another GX?
I hope someone can give me some pointers on how this can be done.
