I observed a strange behaviour this morning while I was wondering why there is no solar power at all. Everything seems normal, no fault codes or are other obviuos problems... But then I opened the Victron Connect App and checked the MPPT directly... and there it was, a negative temperature of -273°C. The temperature disconnect is activated by default at 5°C, so in the end the behaviour was right, but where does this negative temperature comes from?
I have a SmartBattery Sense connected in the network, that is sharing the temperature with the MPPT charge controller. But the Battery Sense showed correctly the 16°C at that moment.
Finally a restart, disconnecting Solar and Battery, solved the problem. Let's see if this was only one bug in about 8 weeks runtime only...
Did someone of you observe a similar behaviour?
