i have installed an ESS with 1x SE7K on AC-in, 1x SE15K on AC-Out1 and 1xMPPT RS450/100, with 3x Multiplus II 48/5000.
Some of the instructions of the Victron/Solaredge AC-Coupling manual are not very clear...
1. How to enable APS via Multi Relay Output?
1a. which is the correct relay?
I want to use the blue "AUX RELAY" for that:
Its named:
- "AUX-RELAY" at the Multi
- "ALARM CONTACT" in the Multi Manual
but none of these names is available in the VEConfig "programmable relay" Assistent:
I assume, the first option "Use primary programmable relay" is this blue "AUX Relay"
correct?
1b. how to configure it?
first -> "Set relay on" to have it configured as "normally open"
correct?
then -> check "AC Input", correct?
-> then choose no extra options to trigger the relay?!
-> and then.... set it to "when AC1 is not available for 0 seconds"??
So the relay should immediately trigger, once Grid fails, isn´t it?
Or does it not work correctly with 0 sec. and i need to choose 1sec or higher number?
2. ESS assistent setup of frequency shift?
the Victron/Solaredge instructions call out, to use these values.
Is this really correct??
Those numbers seems to be a very tight range?
I am used to Fronius AC-Coupled System, which allow up to 53Hz before disconnecting the PV-inverter.
Does the 51,5Hz really work sufficient or good with Solaregde?
It seems to be very small room for frequency regulation?!
But maybe i am wrong with that, and Solaredge works super fine with these numbers?! I don´t know. Does anyone have experiance on this?
