I'm trying to remotely change the "Active input current limit" with the Cerbo GX Touch Panel on a 3-Phase-Quattro-system and also with a PLC connected to the Cerbo GX with Modbus TCP using com.victronenergy.vebus Register 22, but non of these remote ways seem to work, the only way to change it at the moment is directly with the VE.Bus system Configuration.
I have configured the AC input Current Limit box to "Overruled by remote" as it says on the Cerbo GX Manual.
I would appreciate any king of advice / assistance.
Thank you.
